Plate swapped my KBD MAJA build. This is a POM plate from Green Door Geeks. I hadn’t paid much attention to plate material in previous builds. That changes going forward. The POM plate is so nice to type on.
Is that MO-RA with fans in the background?
Yup!
I have it under the table, like a passive radiator.
Summary
Also plate swapped my GMMK Pro, and got rid of the extremely mediocre “GOAT” stabs in favor of TX. SUCH a big sound improvement.
Totally not “next week” as I said, but I think I found a solution that works. XHT-BDZ!
I eat my words about it being similar to DG; it’s not. Very workable and because of that… Works. It’s the most success I’ve had with any mod. I doubt it’ll be my go-to mod for a long time, but for now, it works.
My Wordpress workbench, that is; I’ve added a new feature to my site.
While it’s generally geared towards fellow keeb super-nerds, I’d also like it to be useful for people who aren’t necessarily neck-deep into the hobby or even into it at all, so I’ve written-up an in-my-own-words glossary of keeb-related terminology I’m likely to use on the site.
If anybody is bored, take a look and see if I missed anything or wrote something upside down. :upside_down_face:
Cheers!
Good for you dude, right on. Proper stabs are so important.
Been working on this for the better part of the day :joy:
I looked through the glossary while using my Hidari so two terms I noticed missing were “FRL” and “southpaw”.
Not sure how often you actually use those so maybe they don’t need to be there.
Added - thanks!
Hmm, here’s some more if you like them:
  • IC (Interest Check)
  • Top-mount (because best mount :stuck_out_tongue_winking_eye:)
  • JWK/Durock (since you have Gateron and Cherry)
  • WKL
  • HHKB (both keyboard and layout)
  • Tsangan
    *ANSI/ISO
^ think these are pretty commonly heard/said
I think that could fit into the definition for ‘Fullsize’, that would technically be ANSI 104 and ISO 105 right?
I think maybe mentioning ‘Arisu’ in the definition for ‘Alice’ could also be helpful for anyone new to keyboards as thats a term that shows up often when searching for Alice and Alice-style layouts.
Oh, I thought they were size-agnostic layouts. Like, 60% ISO has the L-shaped enter, etc.
I think you’re correct. I was speaking in terms of the definition for ‘Fullsize’, where ‘ANSI 104 and ISO 105’ would be a more concise way of saying ‘standard’.
@sarvopari @huhsh Thanks very much for the suggestions! I’ve added those and quite a few more - and learned a thing or two in the process. Love when that happens.
Nice!!
Just one potential edit: Arisu is an Alice layout with arrow keys. Please fact check me, but I’m pretty sure that’s how I’ve seen it used.
Don’t it have a slightly different angle of the split to? :thinking:
And also does not have 2 B’s?
Finally found the original IC post; yes, it appears that is the key distinction, no pun intended. Not sure about the other factors yet but the arrow keys is what the post focused on.
