What is on your desk today?
:crab:
I was like… I don’t get it… OOH :crab:
Stunning pairing with those caps on the pink Tenet
And also kind of an unplanned nod to KT having left the building for a little bit :sweat_smile:
Good layout for mouse users.
They were definitely worth the wait!
Would love to see such a keyboard, but still with MagicForce 68 style navigation blocks on the right.
That would be ideal for my ham radio shack computer, where function keys are essential for running contest macros.
When the locker at work is not big enough to store the Heavy-6, it’s HHKB time :relieved:
My current setup with Zoom65 and BobaU4t, pretty love it
Bakeneko65
  • MT3 Black Speech
  • Invokeys Black Sesame V2 lubed
  • TX V3 stabs (fits so-so with o-ring)
  • Stock FR4 plate
  • Soft o-ring
  • Silicone weight, no foam
Noisy A/C in the background. :stuck_out_tongue:
This build has a bony, yet mostly clean sound - save for some spring wiggle. I’m not sure I’ve ever tried a factory switch that’s managed to eliminate that completely.
NightFox (Input Club + mtt3o WhiteFox Vera in black)
  • TTC Ace linears
  • AE Staebies
  • MT3 Darkness
  • PE foam & force-break mod
  • Modded plate from “TrueFox” —> “Aria” layout
Early impressions - let’s do bullet points about it:
Bad news first:
  • Case screws are dainty, not metric
  • Stabs are cheap, plate-mount
  • No warranty, de-soldering required
  • Salvaged switches not fully functional; only good for springs & small parts
Middlin’:
  • Supports LEDs, but doesn’t come with any, and only single-color
  • North-facing is good if you want to add LEDs and have backlit legends, but not so good if you want to use Cherry profile keycaps and the like. Not really a “negative” because some prefer North-facing, and even if not, it’s easy enough to overcome with short travel switches or spacing shims - but it is a potential reason someone might choose a different chassis
What I like:
  • Lots of layout options on the PCB
  • Supports better stabs including screw-in (having an either/or option is rare even today)
  • USBC
  • Edge-mount; it’s a tray, but the “standoffs” are evenly spaced around the outer edge
  • Easy enough to remap
  • Actually protective carrying case
  • Open-source everything
  • Feet aren’t adjustable, but use a standard available in various sizes
Waxing about this thing in 2023
As a $40-ish rescue project, this was fun - and I have to say I enjoy the final product more than I expected to when I started. 10 years ago when the first iteration of this keyboard was designed, the hobby was indeed in a very different place. As such, this chassis lacks many features now considered standard.
That said, there’s still a good keyboard buried in there - it just takes a little effort to squeeze it out. I did this one in a leisurely setting (literally on a plank of wood in my lap on the couch) over about 8 hours. If you skipped experimenting with modding the plate and subsequently fiddling with stabs, I bet it could be done a lot faster.
Straight out of the box it sounds and feels rough. This isn’t really a surprise - I’m pretty sure every pre-built (or pre-assembled kit) from 7-ish years ago feels rough. These days even ultra-budget keyboards like CIYs and RedDragons have features like isolation mounting and layout customization, making this one seem pretty quaint in a lot of ways - especially considering the MSRP. In [current year] there’s no reason to spend that on a keyboard like this - but for $30 plus shipping, that’s a little different.
I think I’d actually considered buying one of these the last time I saw them on sale and balked at the weird layout - this time I actually just didn’t notice until after I ordered - so I was stoked to find out the PCB supports all kinds of options. The included plate is set to a particular layout, but it’s soft enough to modify with flush cutters and the plate files are available for download.
So - while the chassis lacks many modern considerations that are genuinely standard these days, the PCB is thoughtfully designed and remains pretty darn versatile. I made a quick-and-dirty mod to the plate so I could use my preferred layout - that made the backspace stabs a lot harder to dial-in - but once I got those sorted I really started to enjoy this keyboard. There’s something satisfying to me about a solid, simple tool that does a simple job well - I’d say this build falls into that category at this point.
If you’re wanting to polish a turd into diamond, this may present a challenge - there’s definitely a tuning ceiling here thanks to the slim design and basic mounting - but it may also be higher than it first seems. Use the provided plate files to have a POM replacement made, add a little tape and foam to some strategic places, upgrade some components - you might be surprised how enjoyable it becomes.
I love my fancy keebs, but I also really appreciate one that’s nice to use without being precious - like a trusty wrench. This is a keeb I don’t have to think twice about tossing into a bag, using in static-y winter weather, or typing on 'til the cows come home. There’s a good chance it’s going to last as long as I need it to - but if it doesn’t, I’m not out “keyboard money”.
Foundation with Terrazo top.
I just happened to have Soware sitting out so I put it on here. Plan to swap out to Polybius soon. This is using vertex v one switches. I love them. Top stock switch for me.
Anywhoo, posting some bad photos because I love the look and needed to share.
This is really not helping my urge to give the 980C a shot. That’s a thing of true beauty!
Maan, maaaaaaan. I’m trying to save the money.
Little refresh on the ALF this afternoon. Still using the TKC Blackberries, but a new color on the face. Contrakey Blue on Bluish.
consider yourself enabled
LEOGANG
Noooo! Thankfully (or unfortunately) for me they seem fairly rare on the secondhand market so I may have to sit this one out for a while.
I could get you a black one. Around 250 Euros. :grin:
How many sets of Ursa does it include? :grin:
Haha, none as of now. I’m still on my mini printer, and doing a set for myself will probably take me 15 days of printing and legend filling. I’m not feeling it, not with this heat around the fumes.
