What is on your desk today?
The Keydous NJ98 with a number pad, as well as the volume + knob
It feels weird to me to see the Enter and \ switches being rotated for ansi layout, the Cherry MX spec doesn’t have a symmetrical stem
Great idea! I wish I had one of these. Maybe I can find someone with one at a local meetup. So after doing this, is your |\ (pipe) keycap level? Mine is slightly elevated on the left hand side, and I found that for some keycaps, my switches will reject the cap and forcefully push it off :stuck_out_tongue: I haven’t noticed any issues with the Enter key.
Mine seems level - it probably depends on the switch, and if it has any resting N/S tilt. I know when I was working on one of these for a buddy a while back I was having issues with the pipe key appearing slightly rotated - I think I may have ended up using a different switch for that key on his build.
Good point! I will say I used the Wuque stabs in mine, but didn’t noticed the same issues you mentioned. Honestly, I really like that board. Super easy to throw in a backpack and take to and from the office. I also think I have come to really prefer this style 65% layout over the standard 65% with one blocker on the bottom row. Having the arrow keys be that little extra exploded really seems to help me find them better.
I dig the little display that protrudes.
Where’d you find a clear version anyway?
It is custom case :joy:
Ah, okay, that makes a lot more sense now.
what’d ya make?
CircuitMess Chatter 2.0 walkie-texties:
I must have these. Looks like they’re a Sam’s Club exclusive, but I wonder if they’re just the same as the LoRA versions they sell elsewhere?
Rama U80-A Seq. 2 with GMK Houhai
Keycap I am working on rn
I built my Fjell over the weekend, and have been enjoying it this week!
Banana Splits on full brass
No foam
Durock V2 stabs
CRP R4 Tulip
Looks as good as my gray Fjell. Banana Splits on brass is not bad but I found Black Lotus on FR4 is pretty good on Fjell.
The nice thing about these tray mounts is that they are so easy to swap internals out. There is a lot to explore with this one, and I’ll likely try many different builds.
The Fjell is still so good to look at.
Tenet with Blueberry Chiffons on Alu, Retro Beige ASCII caps from 21KB
(apologies for the bad crop :smiling_face_with_tear:)
:crab:
