Hello everyone
This is Vortex Keyboard
Some of you may have known us through our previous models, such as Pok3r、Race 3 or Core.
We’ve launched “KBt RE:” & “PC66” recently (a tribute to IBM PCjr)
And we are excited to announce to you that we will release Model M SSK KIT later this year
● Layout: ANSI / ISO (WK & WKL)
● Gasket mount structure
● Case Material : Aluminum
● Weight: Approximately 2kg
● USB-C Connectivity
● PCB will be available in five versions,and they are all with QMK/VIA/Vial support
ANSI hot-swap PCB (Spacebar: 6.25u)
ISO hot-swap PCB (Spacebar: 6.25u)
ANSI hot-swap PCB (Spacebar: 7u)
ISO hot-swap PCB (Spacebar: 7u)
ANSI/ISO solderable PCB (Spacebar: 6.25u/7u)
※Compatible with MX and MX clone switches ※Only solderable PCB supports stepped Caps lock.
*Include
PCB x2 (Main PCB and F-row PCB)
Aluminum Case x1
Plate x1
Poron foam x 2
Gasket set x 1
Vortex aluminum badge x1
Screws set x1
Rubber feet and hex key
*Price
The final price has not yet been decided.
All we can tell is that it will be under 300 USD.
Joinus on Discord for more latest update and information
I love the attention to detail and the design choices made. To me, this is a great example of a design inspired by something classic evolving into something new.
This was the area I was most interested in seeing.
I remember there was a previous interest check that was scheduled to run for a similar model M tribute board that used a flexible PCB and curved plate. I think it was TKC who planned to run it, but it never happened. Obviously that is a more difficult endeavor and not really necessary if you use sculpted keycaps.
The straight bottom edge of the keycaps does look a bit awkward next to the curved detail of the case. Maybe it’s just the angle of the photo, but it seems like the bezel should have been raised a bit to cover the bottom skirt of the keycaps (also better for hiding the switches)
Still a very lovely idea and even nicer with the included case!
For anyone curious about the firmware, I found Vortex’s Github repo, but it seems to lack firmware source for the model M.
(I’m on a quest to add host autodetection to my various TKL’s, so I need the source to rebuild the firmware with my additions – hence why QMK compatibility is a must.)
