Hi Everyone, My name is Gary, the designer of G-Concept, my studio had been join together with Gugu Studio. So our new studio called G-square Studio means G-Concept x Gugu.
Last year I had launched Vintage 80s, 980mini and Space Trek. Only Space Trek had sold internationally. The reason is the Vintage80s is too big and heavy to ship.
Vintage80s
The upgrade version of vintage80s
Space Trek
After this I had spent nearly a year to prepare the Vintage60s! The Vintage60s is a fresh design on the current market, which can support HHKB, 60, 64, 68 and 84keys. Simply just change the top plate and re-positioning the pcb. Let see the pictures below to explain more clearly
With HHKB top plate
With 60% top plate
64%
With 68% top plate
without any top plate
All the parts and bits is included in the standard package, user can change around themselve. Pcb will comes with 2 pieces, one of them is hot-key swap, and the other is multi keyset.
Let see the actual proto-type
The outter shape is kinda the vintage typewriter design which is my fav! With the pvd bits, which will look more elegrant. This time I had add a little gadget, this idea is originally from the old IBM keyboard, which is the “Solenoid valve”. This can imitate the sound of the old typewriters, which is noise, but FUN! The Solenoid can be turn off whenever you don’t want it.
Full re-programmable with Qmk/VIA, pcb do not have bluetooth, but with bluetooth ready, I have leave a port to connect an external bluetooth, the case has place for the battery.
This is my new project, and I hope you will like it. The Vintage60s will up om sell in dec, the actual date not fix yet. the CNC and pvd had finished already, and the case is waiting to put the color coating. Once is done, I will update the details and pic asap.
Thank you for reading my post. If you have any comment, please feel free to leave me a messsage. Thanks
