Silent Spacebar "GhostBar" for Custom Keyboard Enthusiast
Attention all keyboard enthusiasts! Are you tired of the hollow sound of your spacebar? Do you find yourself trying all sorts of DIY hacks to no avail? Well, say goodbye to your troubles and hello to NuPhy GhostBar!
Introducing GhostBar, the ultimate solution to your spacebar sound woes. Our innovative design is specifically engineered to reduce that annoying hollow sound, giving you a more satisfying and enjoyable typing experience. And the best part? It’s incredibly easy to install - simply swap out your old spacebar for GhostBar and voila!
Don’t let an annoying spacebar sound ruin your typing experience. Upgrade to GhostBar today and experience the difference for yourself. Trust us, your ears will thank you.
Length: 6.25u
Material: PBT
Colors: Nine options
Profiles: Cherry & KOP (similar to OEM)
Noise reduction solution: 1u built-in silicone cavity
