I’ve just finished lubing and silencing my Realforce and I had hoped that the spacebar rattle would be eliminated with some lube. As you can see from the following video this has not been successful. I was wondering if there was perhaps anything else I could do to remedy the rattle. This thing is going in a Norbaforce ghost with 1992 caps for my daily driver so I want it to be perfect.
A little goes a LONG way. Things go from sounding like a bag of nickles to zero key return. Hope this helps.
Hi, I think the solution to your problem is found in my guide under step 8. I have silenced many topre spacebars with this heat shrink tube stabilizer bar mod!
