Live 100
Designed by Bat Knight Studio
Intro
Hello every one, we know you are waiting for 100% layout BK series keyboard for a long time, so we would like to introduce a new full size keyboard designed by Bat Knight studio - the Live 100!
Gallery
Description
Compared with BK75, Live100 has been upgraded in many aspects. First of all, in terms of software support, Live100 has confirmed to support QMK/VIA, the battery capacity has also been expanded to 8000 mAh, the wrist rest has been upgraded to a high-protein leather hand rest, and the black gold version also has embroidery on it, which is very wear-resistant. The magnetic plate is made of aluminum with two-color anodizing process, which is sturdy and durable.
Highlights
QMK/VIA support
8000mAh battery meet the needs of long-term use
PBT Keycaps with metal style characters
Embroidered wrist rest
98 keys gasket mount design, hot-swappable switches gaming keyboard
Wrist rest, dust cover, keyboard display stand 3-in-1
Use the Hall switch/sensor, the keyboard will automatically turn on or off when the Wrist rest is covered or spread (Only in BT and 2.4G mode)
Removable magnetic keyboard top anodized CNC aluminum plate (Black Gold)
Bluetooth+ 2.4G+ Wired, Supports up to 3 Bluetooth Devices, Low-latency Fast Response
Full-key with Rogers Poron Switch Pad
Customized POM switches, office or gaming are both suitable
Two-stage system switch and footstand
Specifications
Brand: Bat Knight
Keyboard name: Live 100
Number of keys: 98 keys+1 knob
Mount: Gasket mount
Product net weight: 1.4KG
Size: 405mm(w)*145mm(h)(Wrist rest 85mm)
Front height: 20mm
Keycap Material: Doubleshot PBT
Keycap Process: Five-sided sublimation
Keycap Thickness: 1.5mm
Switch Name: Bat Knight Orchid V2
Switch Type: Linear
Switch Rating: 50 million presses
Switch Actuation force: 40±10gf
Switch Bottom out force: 50gf
Switch Actuation travel: 2.0±0.6mm
Switch Total travel: 3.3mm
Standard factory lubed only
Connection: Type-C
Battery capacity: 8000mAh
Polling rate: Wired, 2.4G(1000Hz), Bluetooth(125Hz)
Working voltage: DC 5V±5%
Wired: DC 5V±0.5V
Wireless: 3.3V–3.7V
Working current:
Wired: ≤500 MA
Wireless: <210 MA
PCB: flex cuts, 1.2mm thickness
Wireless transmission distance: max around 8–10 meters
Backlight: RGB, with programmable software
OS support: Compatible with WIN, MAC OS
Anti-ghosting keys: Full keys
Cable length: 1.5m
Unboxing
Pre-Order Info
Pre-order Price: From 134USD (Free shipping in some countries such as Korea, Japan, Singapore, etc.)
Pre-Order Time: Oct 29th - Nov 5th 2024 GMT+8 (Ships during Nov 8th - 10th )
Please feel free to ask us any questions about the keyboard below!
Welcome to join our Discord and follow our Instagram,TikTok for more discussion, latest update and questions!
