PMK/SP Switch Blockers?
Has any one used the PMK/SP switch blockers or have pictures of what they look like from the side / underneath?
Manna Harbour used them in a build recently, don’t know if they’re on this board as well but you could try writing to them on reddit. Either way, the blockers look super dope.
I’m genuinely curious why and how these are used. What piqued your interest?
I sent them a message. :wink:
Source: https://www.reddit.com/r/MechanicalKeyboards/comments/i0a53z/smolboat_ortho48/ / https://imgur.com/gallery/UlBKFDS
I used them in a few builds back in the day, they work so well with a black Filco that they seemed made for them.
You need to remove the stem or the switch will be constantly depressed, and they do not work with speed silvers and presumably other reduced travel MX switches
