Need help finding a 65% wooden case
Starting my first ever custom keeb build and was wondering if there were any 65% wooden cases out there because I could only find 60%s.
I haven’t seen any. 65% isn’t really standardized like 60% is where you can just get like any case and PCB and they will work together
This guy makes them to order:
I have 2 of them. The first one was beautiful. The second one wasn’t as pretty on the inside (not that you’ll ever see that).
Here’s my case from him in maple:
https://www.instagram.com/p/Bxla555FEOc/?utm_source=ig_web_copy_link
Here’s my case in hickory:
https://www.instagram.com/p/ByDwh6qFEBi/?utm_source=ig_web_copy_link
They have holes for using screw in aluminum feet, but I use them flat.
That’s awesome! Thanks.
In addition to those Datamancer used to make them for the Whitefox, but it has been discontinued.
I used one of his cases for my Scrabble board. The only issue with mine was that the texture was much rougher than I had expected and I ended up having to sand it down myself.
Yes, I had a few spots that needed sanding on my hickory board. I was surprised because the first board I bought from him was flawless and smooth as silk. What wood is that scrabble board?
that photo is awesome, by the way
Thanks. Mine is also hickory.
Ah. So maybe it’s somethign to do with that particular wood. Interesting.
