If you hadn’t posted the picture I would have had no idea what that color scheme was in reference to. Had they come up with some Castle Greyskull colors I would have instantly recognized that.
looks more like a TFUE set to me. Guess NK got to it first and they had to rename
This colorway does not remind me of He-Man in the slightest, even trying to play it off calling it the Prince Adam base. I think @pixelpusher hit the nail on the head. This was made for something else, at least I hope so LOL!
This is exactly the kind of thing I’m looking for.
70% boards and larger that are available on AliExpress. Solderable.
I have a TKL in the GB phase, but I’d like to build something sooner with a VA68 layout. Or at least a 65% with large shift keys.
People here seem on the up-and-up about what’s out there. Can anyone recommend affordable 70% boards or larger, available on AliExpress and the like? Ideally, something with a soft plate option like polycarb, POM, or even CF.
Weelll…
GMK Skeletor is in stock at Originative.
Ashkeebs has some black WKL TX Rev.3 stab sets in stock right now if anyone has been looking for them. https://www.ashkeebs.com/product/tx-stabilizers-rev-3/
Also in pre-order at Drop haha
It’s been in stock for some time now, but I never bought it b/c they spilt up the accent pack and made it an enter accent only. Lame
Man! All variants were already sold out except for the black WKL ones. I don’t have any WKL boards, but I do have a ton of extra wires, so I should be good.
Don’t quote me cause this is the first time I’ve managed to grab some TX stabs, but I believe they use a regular diameter stab wire so any 6.25 wire you have should work.
mekibo will have some extras soon as well, so all hope is not lost
Don’t know anything about the manufacturer, but the description sounds promising.
I ordered some from DangKeebs, I’ll be sure to describe what they’re like when they come.
NicePBT Sweater Weather is in stock at Cannonkeys for 84.99 + shipping
Well, these boards I’ve been using would probably not fit what you want… Typically they are hot swap, and don’t really have plate options. It seems like this layout is fairly under-appreciated in the community (I had to search hard to find 10-12 of them), so options for getting alternative plates, plate foam, etc. are pretty non-existent. And, all of them have been post mounted without any mounting alternatives (unless you modded them heavily).
https://kono.store/collections/memorial-day-sale
Kono is having a Memorial Day sale. A few items I thought worth mentioning:
Bob Ross deskmats
Kailh Speed Bronzes & Pinks (non-Box click-bars, Pinks are re-colored Bronzes that were supposed to be specific to one vendor but got oops’d out into the wild - caveat with these is reports of actuating before the click)
Box switches for cheap; just be aware the Royals are pre-retool. Looks like Kono has some less common (vendor exclusive?) variants of the standard boxes; basically slightly lighter-weight versions with different colors.
Nightwalker switches (glow in the dark JWKs - notable for having a fast-curve spring; can’t think of too many stock switches that come with these besides the Halo Clear)
Lots of Hexgears stuff; their Gemini boards are based on the same open source design as the Drop CTRL, and they have some low-pro Choc stuff, too, including a bluetooth full size
And Keyfirst Blings are on sale as well. That’s my cue to pick up the pinks since I’ll get along with that spring weight better. Their TTCs are on sale too.
Switch Oddities also has a Memorial Day Sale, 10% off orders above $10. I ordered 69 different items
Nice.
