I see now. The kit is pre-assembled. I guess they are saying on the page that since it’s a bit difficult to assemble for the average person, they’re currently only selling it assembled.
So you could do the PCB and plate and source the rest of the parts. I’m assuming the plate holes are not tapped.
They don’t have silencing rings but said they were open to install them if you sent it to them.
Now the things get interesting:
Current stabilizers are Costar style one buy they plan to do a new iteration of the PCB that will support pcb screw in stabs. The pcb size has the same footprint and should fit most GH60 sized keyboards. Also asked if the PCB can be used with a daughterboard and they said yes.
Another interesting part is that I asked if they could edit a .dxf file to convert one existing mx plate file to support the housings/sliders&EC pcb and they said yes, just to send them the file and they will modify it.
So basically, I feel we are very close to the EC dream… get the new revision PCB with screw in stabs, add topre/deskeys/NIZ/SRZ Kbd store housings&slides, get a custom plate for one of favorite case boards and turn it into EC.
Right now there’s a lot of new info and questions about quality, feel, tolerances and case compatibility, and will probably put a pause on my quest and wait for more info and review from others, as my time is very limited nowadays.
I think the cross is supposed to be part of a + - control a la volume control (or at least look like it) but them being crammed together definitely makes it look like a cross. And I’m not surprised to see less, but better in some of the renders. It seems strongly influenced by that design philosophy.
Not so confident with the USDM vendor selection though. I feel like they’re too new for a board this expensive. I feel like there’s a snowball’s chance in hell that’ll go for anything less than $500 with all the options they’re considering.
The name is also reminding me of a certain Monke who tried to wrangle the Topre Deskmat group buy with Kumamech/Polartech. An experience I look none too fondly on.
No clue what it’s like, but I’d imagine extra crunchy
They’ve also got their own, non-weeb version of the Lucy silent.
NovelKeys has a bunch of on clearance / flash sale, mostly special editions of NK65s and NK87s. Nothing’s blowing my mind here but if you wanted a nuclear-green keyboard with GMK Awaken on it, it’s available at a modest discount.
I actually kind of dig the Lucy’s colorway… I have yet to toss them into a board, but in hand they are feel pretty good. Don’t really have any other silent switches to compare them to, though.
I am kind of avoiding getting into the clicky switch side of things, as I think light-to-mid tactile is about as far as I can go with my sensory journey with keyboards.
As far as full POM switches go, I also have yet to try out my Clackbit switches as life has gotten in the way.
