Hey folks! Just wanted to let you know that lucky65 is back up for sale today due to popular demand. If you missed out on the group buy last time, make sure you don’t miss it this time!
Intro
Introducing the Lucky65: Reigning Supreme as the New Budget King of Mechanical Keyboards in 2024!
After the success of Choice65 last year, we’re thrilled to unveil its worthy successor: the Lucky65! Setting a new standard for affordability and quality in the world of mechanical keyboards, the Lucky65 is here to redefine your typing experience without breaking the bank.
With its sleek design, innovative features, and unbeatable price point, the Lucky65 embodies the perfect balance of performance and value. Whether you’re a seasoned enthusiast or new to the world of mechanical keyboards, the Lucky65 promises to deliver an exceptional typing experience that will elevate your productivity and enjoyment.
Join us as we embark on this exciting journey with the Lucky65, the new budget king of mechanical keyboards for 2024 and beyond!
Media
Features
- Compact Design: At just 65%, Lucky65 offers maximum functionality in a minimal footprint, optimizing your workspace without sacrificing performance.
- Premium Build: Crafted with 6063 Aluminium material, Lucky65 boasts durability and longevity, ensuring it stands the test of time. Its smooth and matte finish lends an air of elegance, while subtle branding, including the distinctive four-leaf clover logo, emphasizes the theme and adds a touch of refinement without overpowering the overall design.
- Customizable: With hot-swappable switches and fully programmable keys, Lucky65 empowers you to personalize your typing experience to match your unique style and preferences.
- Dynamic Lighting: Illuminate your workspace with vibrant RGB backlighting, customizable to suit your mood or environment.
- Effortless Connectivity: Lucky65 features versatile connectivity options, including wired and wireless modes, enabling seamless integration with any setup.
- Highly Personalized : The exclusive Lucky65 personalized keyboard customization software provided by the factory can not only set the lighting mode but also freely change the keys, increasing the diversity of use and making the keyboard more in line with your personal needs.
- Precisely adjusted stabilizers: After multiple precision calibrations, XinMeng stabs have reached the industry’s top level in terms of stability and typing feel, allowing you to enjoy an unprecedented typing experience during the typing process.
- Hidden switch: The hidden switch does not affect the appearance of the keyboard, and it brings a more attractive user experience. It is under the TAB, you can switch to wired mode by using the switch or pressing FN+TAB.
- Long-lasting battery life: The Lucky65 offers a 3500mAh battery, delivering up to 2-3 weeks of usage without RGB. Long battery life ensures uninterrupted work and entertainment, allowing you to stay productive and stay connected wirelessly for longer, without the need for frequent charging. What’s more, it allows you to charge and use at the same time in wired mode.
Review
Milky White: Edward Tanujaya
Milky White: Hi_keebs
Milky White: Cloudnoela
Milky White: Jeorgepaolo_
Black: Mangokeebs
Black: Thoccnology
Black: Samuel Tan
Wave Blue: Lewis Toh
Wave Blue: MCZ Studio
Carmine:Typebea
Carmine: Keebdude
Carmine: RiceCloud
Navy Blue: Seungup KBD
Violet: Cyan Key
Violet: Wabi Sabi
Violet: Keybored
Violet: MilkCloud
Silver: RX003
Silver: NearLucid
Silver: Merkeebs
Specs
- Connectivity: Wired, 2.4G, BT5.0
- Material: 6063 Aluminum
- Surfacing: 150 Mesh Anodized (Carmine, Silver, Black, Navy Blue, Violet) ; Electrophoresis (Wave Blue, Milky White)
- Weight: Gold Anodized Aluminium Weight
- PCB:1.2mm Thickness ; ANSI Support or ISO Support ; Split space Support(Need additional plate) ; With Flex Cuts ; Plate Mounted Stabs Compatible
- Net Weight: 1.2KG
- Size: 326mm * 115mm * 33mm
- Plate: 1.5mm ; PC material ; Support ANSI
- Front Height: 20.5mm
- Compatible System: Windows XP, Win7, Win8, Win10, macOS
- Stabs: XinMeng V2 plate mount stabs ; Factory Lubed
- Rolling rate: 1000Hz (wired & 2.4G) ; 125Hz (BlueTooth)
- Battery: 3750mAh
- South-facing RGB
Price
Whether the surfacing of the case is electrophoresis or anodized, the price will all be set at US$84.99 on our official website.
