[IC] ZX75 | IQUNIX.com🏆| ENTRY-LEVEL MECHANICAL KEYBOARD KIT
Hello there,
This is IQUNIX, a company dedicated to peripheral design from top to bottom and from the inside out.
IQUNIX Super ZX75, a 75% Gasket Mount Aluminum mechanical keyboard kit launched by IQUNIX Super as the second customs board after 1+1.
Following the design standard of IQUNIX Super Series, you can absolutely tell it is from IQUNIX!
A significant upgrade from our pre-built ZXX75 PC version keyboards, catering specifically to custom keyboard enthusiasts. Fill out the IC form to let us know your opinion, the more specific the idea, the faster we can move the project forward.
OVERVIEW
Meticulously designed with a keen eye for detail, the ZX75 is a true masterpiece that perfectly blends aesthetics, performance, and utility. The detachable magnetic feet allow for adjustable typing angles, providing extra comfort and convenience. Additionally, the intuitive extra media knob enables users to effortlessly control video and music. Featuring a professional, low-key appearance, the ZX75 boasts a highly-textured, stylish design that seamlessly integrates into any complex desktop configuration. The harmonious and natural design offers both practicality and aesthetics, making it an excellent choice for an entry-level custom mechanical keyboard.
SPECIFICATION
:round_pushpin:Typing angle: 6° (without feet) / 9°(with feet)
:round_pushpin:Gasket Mount
:round_pushpin:Interface: USB-C
:round_pushpin:Aluminum Cases
:round_pushpin:Cherry PCB-Mount Stabs
:round_pushpin:Connection: Wired / Tri-Mode
:round_pushpin:Software: QMK (Wired) / IQUNIX firmware (Tri-Mode)
:round_pushpin:Dimension: 346mm * 152mm * 17mm(front height)
:round_pushpin:Compatible Switches: 3-pin & 5-pin Switches (Cherry MX and clones)
Highlight Features
Magnetic feet Tactile Media Knob
Indicator light (next to the knob)
CNC aluminum ESC novelty keycap
Tri-mode available: Bluetooth / 2.4GHz / Wired
Unique design theme on the bottom case and top case
ABOUT CASE
All CNC Aluminum CasesIQUNIX has an alias “Aluminum Factory” given by our users. As the name suggests, aluminum products are the strength of IQUNIX. With 9 years of experience in this field, you can always trust us.
:bulb:8 Different Case ColorwaysFor IC, there is Alice Blue, creamy white, pure white, red, green, silver, gray, black, and purple. Vote your vibe in IC form.
ABOUT FIRMWARE
:bulb:Wired connection with QMK firmware
:bulb:Tri-mode connection with IQUNIX firmware
ABOUT LAYOUT
:bulb:ANSI / ISO OPTIONS
:bulb:Spilt Keys Let us know what split keys you need.
The final decision of making it a universal PCB or two separate PCBs will be based on your selections.
ABOUT PLATE
:bulb:FR4 / Aluminum / PC / Brass Cut or non-cut?
WEIGHT BARS
:bulb:IQUNIX Logo ONLY
:bulb:IQUNIX Logo with two hyphens
We need your vote in determining the final design.
EXTRA ALUMINUM Novelty KEYCAP
:bulb:A CNC aluminum ESC novelty keycap Crafted with high-precision machine engraving, it provides a high-end vibe to the ZX75.
FINAL WORDS
We’re excited to see how it will be received by the community. Please fill out the IC on IQUNIX. com and let us know your preference. May you have any questions, leave a comment below or join Discord to communicate with more keyboard enthusiasts. We appreciate your great support in any way.
Thank you,
IQUNIX Team
Update: GB has started from 15 July till 15 Aug
Learn more here: ZONEX 75 Keyboard Kit | IQUNIX SUPER SERIES – IQUNIXSuper
