[IC]Mingding Linear switch
Hello,This is Moyu.studio
This time we bring the Mingding switch, which is a switch with Chinese characteristics. Its creative inspiration comes from an ancient Chinese container
This type of container was a symbol of power in ancient times, similar to a crown and scepter
We designed the Mingding switch inspired by its color
I also hope to bring you a sense of solemnity and solemnity
Mingding switch specifications
  • Linear
  • 21mm lengthening spring(48g version)/21mm lengthening spring(55g version)
  • U4 Lengthen stem
  • PA66 Nylon top housing
  • PA66 Nylon bottom housing
  • Factory lubrication
  • 5 pin
  • 3.8mm travel
  • Pre-travel: 2.0mm
  • Pressure point force: 48g(48g version)/55g(55g version)
  • Made by Keygeek
On the Mingding switch, we used a brand new keygeek top mold to further enhance the smooth feeling
The combination of PA66 material also makes the sound of the Mingding switch dull, like an ancient musical instrument playing
hope you enjoy this feeling
Sales method: Inventory sales
Price:0.35$/PCS(Adjustments will be made according to the region)
Vendor List:
US:TBD
CA:TBD
EU:TBD
UK:TBD
Singapore:TBD
AUS:TBD
Malaysia:TBD
Korea:TBD
Rest of the world:Moyu.studio
