[IC] JRIS80 - WK/WKL Quick Disassembly, Triple PCB Gasket Mount, LED Strip, Swappable Magnetic Weight, Titanium Alloy Weight, Multi Layout, Tri-mode, Per-key RGB, and More
Hello Everyone,
Thank you for your enthusiasm and patience in waiting for the JRIS80 Group Buy! We’re excited to announce that the GB is just around the corner, set to run in eight days. Before we get started, please take a moment to review the following information about the JRIS80 GB.
JRIS80 Group Buy Information
JRIS80 GB Page
SKUs and pricing
GB Time: November 28th to December 10th
Estimated Delivery: Start packing and sending to vendors and Mykeyclub direct customers around three months after GB ends.
Vendor List:
JRIS80 Information
JRIS80 Render Album
JRIS80 Prototype
These photos were taken by workers using the original Apple camera in natural light. They may not be professional, so please bear with us. More detailed photos and videos will come soon. Please stay tuned for the creator’s content.
JRIS80 Highlights
  • Full CNC 6063 Aluminum Case, experience uncompromised customization kit.
  • WK and WKL are Both Available.
  • Quick Disassembly - exchange the WK and WKL top case. No screws or tools are required!
  • Supports F13 Key and Tsangan Bottom Row, making the front side symmetrical and clean.
  • The LED light strip with Gold PVD stainless steel strip on the front personality and cool.
  • The swappable magnetic weights meet a variety of designs.
    Brass internal weights offer higher density for improved balance and stability.
  • Triple Gasket Adjustment–adjust the typing feel depending on your preference.
  • More PCBs and plates are available. Experience your own custom keyboard.
  • More Add-ons are available for your personal needs.
JRIS80 Specifications
  • Typing angle: 7.5°
  • Front height: 18 mm
  • Material: Full CNC 6063 aluminum
  • Dimension: 36013934mm
  • Structure: PCB Gasket
  • QMK/VIA Supported(wired)
  • Support PCB stabilizers
  • Unbuilt Weight
    With PVD WEIGHT: 2.35kg
    With Titanium Weight: 2.15kg
    With Alu WEIGHT: 1.98kg
  • Built Weight
    With PVD WEIGHT: 2.55KG
    With Titanium Weight: 2.35KG
    With Alu WEIGHT: 2.18KG
Front Design
  • WK and WKL are both available.
  • The layout supports F13 Key + Tsangan Bottom Row, which looks more symmetrical, harmonious, beautiful, and compact. In the position of the Pause key, it can be used as a custom module, which we will provide as add-ons to make JRIS80 more functional.
  • Adopts a LED light strip with a gold PVD stainless steel strip to improve the display of RGB to be more unique and beautiful on the front.
Side Design:
  • The simple and smooth design showed the original intention of JRIS80: Simple and Clean.
Back Design:
  • The JRIS80 still adopts the 2 weights but with a different design. We connected the previous large and small weights to form a closed rectangle with an inverted triangle weight inside. We use rectangles to express the concept of completeness and inverted triangles to express the sense of stability and strength. It also represents that the JRIS product series has finally completely covered 65%, 75%, and 80% layout.
Rectangle Weight:
  • Anodized Alu Weight
  • PVD Mirror Stainless Steel Weight
  • Titanium Alloy Weight
A colorful design through multiple composite processing and coloring processes. The surface texture is used to decorate, and the fine and silky surface post-processing can bring a better tactile experience.
Swappable Magnetic Inverted Triangle Weight:
  • The inverted Triangle Weight highlights the personalized decoration on the back. We use various composite processing and coloring techniques to display the surface pattern. Different designs are options
  • The three-dimensional carving of PVD Mirror Brass Weight will bring another different experience.
  • The magnet installs way, allowing you to quickly swappable your inverted triangle weight.
Structure:
  • Brass internal weight brings a more concise and beautiful internal space, which covers the battery compartment and hides the screws of the external weights. It enhances bottom case stability with increased density and reduces the hollow sound sounds when typing.
  • Triple Gasket Adjustment: The silicon dumbbell-looking gaskets let you adjust the typing feel depending on your preference.
Quick Disassembly:
  • Swappable WK and WKL top cases are easy and quick. No screws or tools are required! No struggle with WK or WKL.
Options for JRIS80
Case Options:
  • 4 E-coat case: E-White/Milky White/Pink/Lilac
  • 7 Anodized Case: Black/Silver/Wine Red/Navy Blue/Dark Green/Titanium Grey/Orange
  • 6 Color combos case: E-White&Black/Orange&Black/WineRed&Black/Navy Blue &Black/Dark Green&Black/Titanium Grey&Black
Weight Options
PCB Options:
  • Wired Flex Cut Multi Layout Hotswap PCB( 1.2mm, No Per-key RGB, support QMK and VIA )
  • Wired Non-Flex Cut Multi Layout Hotswap PCB(1.6mm, No Per-key RGB, support QMK and VIA )
  • Wired Per-Key RGB ANSI Hotswap PCB (1.6mm, Non-Flex Cut, support QMK and VIA )
  • Wired Non-Flex Cut Multi Layout Solder PCB(1.6mm, No Per-key RGB, support QMK and VIA )
  • Tri-mode ANSI Hotswap PCB (1.2mm, Non-Flex Cut, No Per-key RGB, support IRISLab Software)
Plate Options:
  • Flex Cut Plates: FR4/ALU
  • Non-flex Cut Plates: PC/POM
  • Alu and FR4 Half-plate/Brass Plate (Add-ons only)
  • Plateless Build(Add-ons only)
    Noted: We highly recommend using a PC/ POM/FR4 plate for Tri-mode PCB because the Brass and ALU plates may have a little effect on the wireless signal.
Add-ons Options:
What’s in package?
  • 1x Full CNC Aluminum Case
  • 1x Weight
  • 1x Rectangle and default Inverted Triangle Weight
  • 1x Gold PVD stainless steel strip
  • 1x PCB
  • 1x Plate or Plateless build
  • 1x Poron Case Foam
  • 1x Poron Plate Foam
  • 1x IXPE Foam
  • 1x Pack Gasket Silicone column
  • 1x Type-C Daughterboard with JST Cable
  • 1 Set of Footpad
Gift(will not send make-up or replacements)
  • 1x Customized Carrying Case
  • 1x Customized Type-C Cable
  • 1x Silicone pad of battery compartment
  • 2x 2200mha Battery(Only for the Tri-mode version)
  • 1x Customized PVD Artisan keycaps
  • 1x Aluminium Alloy Screwdriver with 2 replaceable bits
  • 1x 2 in 1 Switch puller and Keycap puller
Mykeyclub Team
We are a platform that integrates creativity and innovative design and brings you more fun and cool products. Please participate in our MKC family for more discussions and future updates.
Mykeyclub discord
JRIS80 IC Form
Mykeyclub Ins
Best Wishes
Mykeyclub Team
Does it support Standard TKL PCB? e.g H88, Galatea etc
The Jris80 PCB does not support standard TKL PCB. It is specifically designed for the structure of the Jris80 keyboard.
Hello Everyone,
We apologize for the extended wait for JRIS80, and we are truly grateful for everyone who has inquired about JRIS80’s progress and continuously followed JRIS80 during this time.
Over the past few months, we have been collaborating with IRISLab to continuously refine the prototype, with the aim of delivering the perfect JRIS80 to everyone. The good news is that the prototypes have been gradually shipped to our content creators, and we will also be concurrently updating JRIS80’s review videos. Let’s all stay tuned together!
Additionally, we have made the following updates to JRIS 80:
  • Upgrade PVD SS internal Weight to Brass internal Weight.
  • The position of the add-ons rotary knob has been moved from the F13 key to the Pause key, making the front design cleaner and more user-friendly.
  • The E-coat Orange Case has been replaced with an Anodized Orange Case.
