I’ve got the opportunity of picking up a Professional BT but I’m having a little trouble trying to figure out what the differences are between the Professional BT (PD-KB600B) and the Hybrid (PD-KB800BS). Anyone have any insights?
From what I can tell, visually at least:
Hybrid is latest version
Logo placement on the Hybrid is smaller and in the top left, whereas the Pro BT is on the bottom right
Hibrid also allows you to remap keys from the main + second layer. They provide a software that you can use. Not all keys can be remapped (FN key, etc.) but most can.
I already own a Pro Hybrid Type-S in white which I’ve lubed the sliders and I love it so much. I don’t use the key remapping functionality so that’s fine but I find the Bluetooth feature very useful.
Reason I ask is that a black BT has come up for sale (non Type-S) and was wondering how similiar it would be to my current Pro Hybrid.
The biggest drawback of the BT (Pro 2 generation) is that it cannot be used in wired mode if need be (the USB connection is only for power and not data).
The Hybrid (Pro 3 generation) can be used in both modes.
