[GB] Lumberjack PCB kit R2
Hello Keebtalk, the Lumberjack is back for a round 2. The open source, through hole, built it yourself, 60% ortholinear PCB kit is back.
  • Ortholinear PCB for 60% tray mount cases
  • Designed to be easy to build with minimal soldering experience.
  • All through-hole components, no SMD soldering required.
  • Get that visible component aesthetic in a standard 60% tray-mount case.
  • 5x12 (split Preonic) layout, full grid or 2x2u spacebars
  • Supports both USB Mini and USB-C.
  • MX, Alps and Choc v1 compatibility.
  • FR4 switch plate.
  • €22EUR + shipping
More info: GitHub - peej/lumberjack-keyboard: 5x12 ortholinear through-hole component keyboard PCB for standard 60% cases
Geekhack GB thread: [GB] Lumberjack PCB R2 - Extras avail
Order form: https://forms.gle/7LjG9hPLcS16DDDS9
Have a nice day and be okay.
I’m excited about this one. No clue if I’ll like the layout at all but sounds like a super fun project at a low price =D
Might get two (or more) and teach my daughter how to solder this summer(?). Might even get three and save one for when my youngest is older.
Ordered. Looks great!
I’m jealous of the new silkscreen. That and these build into nice boards. You might even be able to convince yourself that you don’t need a wood case, but I doubt it. I doubt it.
Is this the wooden case offering from KBDFans? It looks quite nice.
It is, do test fit a lot if you get any wooden case. They may need modifications in order for the PCB to fit correctly. I uh, am not sure I can get the PCB out of this case. :clown_face:
the link isnt working for me :confused:
