Hello there! GMK Avanguardia finally reached the GB Stage!
It will run December 15th - January 15th on:
- EU: Candykeys
- USA: Vala Supply
- Asia: iLumkb
- Australia: Switchkeys
- Canada: Deskhero
I made a lot of kitting changes since the IC based on all the feedbacks I had. Here’s a summary
Box Design
I hope GMK can print the inside of the box (I didn’t get back about this).
Kits
As you can see there are more kits but cheaper. I tried to be inclusive as much as possible with the 40, spacebar, numpad and “dark numrow” kits.
Deskmats
No changes apart some minor adjustments
Renders
Collaborations
Prices
Well, it feels like a long journey but I finally reached the end of it.
Thank all of you for the support guys!
Cheers
S
