Ey, this man knows me. Of course that was the first thing I tried.
Borderline unusable, unfortunately - it was so crunchy in a bad way that I didn’t bother testing if it functioned, though I still might out of curiosity.
That said I tried a few other things that were a lot more pleasant - more details on that later!
Ha, maybe so - and yes I tried that last night as well. It’s not bad - definitely a lot better to use than the Cream Tactile stem in the Blue Ink. Before lubing there’s some spring and/or leaf noise but it overall has a nice moderate, rounded feel from the single one I’ve tried in a tester so far.
Have any of you tried Cream housing with Tealio stem? I have read about this combination several times (r/switchmodders), but I don’t have any Cream’s at home to try.
Put some NK Cream stems and springs in Gateron Black housings yesterday, 205g0 lubed house, stem and spring, no film since I dont have that atm. So much smoother feel than a original cream. Also made 1 Creampaca - Alpaca v2 house and spring + Cream stem( only got 1 Alpaca from a switch test bag ). Similar feel to an Alpaca, but a bit more thocky sound, but a bit to short keytravel for my liking. Anyone have a good tip on what I can use my NK Creams for? Will have alot of them very soon when my Alpacas arrives.
I face a weird issue with normal stems in cream housings. If you bottom out and then try to move the stem, it makes a creaking noise. It made the frankenswitch from leftovers from a creampaca unusable.
Pretty tactile switch, clackier than the normal coffee chip. Tactile bump is a bit more rounded as well. Colour combo isn’t too bad. You can also do the same with a t1 stem for a kind of dryer sounding switch, sharper bump and slightly better colour combo.
I have tried UHMWPE - and while I found them totally decent I wouldn’t say it’s worth it to get Creams and umwipe stems just for that.
I have not yet tried P3 stems in them, but I do have some Cobalts, which I’m pretty sure are pre-lubed recolors of Durock POMs - so I’ll give that a try sometime soon and let you know how it goes.
has anybody done anything with box navy stems? I have a few and i kind of like them for a clicky, but what could i do to make it sound a bit deeper, a bit more solid?
I’m not sure there’s a whole lot lot you can do to that switch to get it much deeper, but you might try putting some 106 on the clickbar and bottom-out surfaces, and then using some thin foam on top of the PCB; either the cheap stuff keebs usually come wrapped in, or pre-cut stuff (usually called “switch pads”).
Don’t have any experience with them myself, but I’d say it’s worth experimenting with one or two - I don’t see why they wouldn’t work with at least some other components from other manufacturers.
Im planning to put the stem in a cherry black for colour combo purposes, but i’ll see if it is any good sound/feel-wise. If anything im hoping it will be a little smoother.
