Recently , my best friends ask me this question.In my opition,I think that need not.
As your first mechanical keyboard doesn’t need to have super high customization requirements. While mechanical keyboards do offer a wide range of customization options, it’s perfectly fine to start with a more straightforward and off-the-shelf option, especially as a novice. Here are a few reasons why:
- Simplicity: Starting with a pre-built mechanical keyboard allows you to focus on getting used to the mechanical key switches, understanding the typing experience, and familiarizing yourself with the basics of mechanical keyboards.
- Ease of Use: Customization can sometimes be overwhelming for newcomers. Starting with a standard keyboard layout and default keycap set simplifies the learning process and allows you to get comfortable with the fundamentals first.
- Affordability: Highly customizable keyboards can be more expensive due to additional features and premium components. Beginning with a more basic model can be cost-effective, allowing you to determine if you enjoy the mechanical keyboard experience before investing in advanced customization.
- Learning Curve: Customization often involves programming macros, remapping keys, and adjusting lighting effects. As a novice, it’s beneficial to first learn about these features gradually and when you’re ready.
Exploration: Over time, as you become more familiar with mechanical keyboards, you can delve into customization at your own pace. You can gradually explore options like keycap replacements, modifying switch types, and even building your own keyboard from scratch.
Is it right? Any suggestions?Any keyboard you can tell me ?
