Even if shipping is more expensive if you’re ordering more then like 10g store uni is a lot more cost effective by his numbers.
Coronavirus shipping price. It was very reasonable when I ordered before.
I know that StoreUni has been accused of mixing 205G2 with 105 to make their 205G0, but has anyone proven it yet? Not trying to be a dick or start anything, I’m genuinely curious & don’t think you should be stating it as fact unless it has been proven true.
odd question, do you put together the same top and bottom housing after opening the switch or just open every switch and put the parts random together? I’m not sure if every housing is 100 % the same.
Not an odd question, good question. I’ve heard some, albeit a select few, people claim that It is important to put all the same pieces together when reassembling. I imagine this is more important when lubing old, well used switches like alps or vintage cherry switches as they’ve been pretty well broken in, and less important when buying loose switches as they haven’t really been used. I personally do not. I just mix and match as I can’t imagine it makes a noticeable enough difference to warrant the extra time and effort. I haven’t seen any objective tests done either.
Just random mix of top and bottom housing. It’s not like they were hand selected to match at the factory and they’re all going to be some random degree within tolerance regardless.
Very interesting; thank you both for the reply!
I’ll be interested to see if anyone argues the other view and what their points are.
Hello Christopher! As Krytox GPL205g0 and Tribosys 3204 / 3203 alternatives are difficult to get in Europe, I started on Ebay selling these products. As we are a startup from a couple of enthusiasts formerly working at DuPont, we also sell custom made GPL205g0.
Regards, Tom
The only reasons I believe someone would use the same switch assembly in its entirety:
1- They have a switch opener with a built-in modding base, and no modding stations. It’s one of the reasons why I plan to mod each switch I get one by one. An example is one of those KBDfans alu switch openers which have the switch tester built in (same as I plan on getting). Since you can only have a single switch open and in the base/slot, you mod them one by one and automatically end up using same parts for the assembly of the switch that you opened.
2- Avoiding dust etc from making its way into your modded switch, causing you to mod or complete each switch one by one. Same result as point 1.
3- You aren’t sure if you can do all the switches in a single sitting. Maybe you mod 10 or 15 each day so you don’t hurry at the end and each switch gets same attention… Same thing then. You probably will do each switch one by one.
4- Being a newbie, you don’t to risk anything. Or maybe like me, it’s more satisfying to the individual that the parts go together to the same switch at the end.
5- This point is something I have seen when trying Franken switch assemblies with the switches on my huge switch tester.
I removed two switches, made a Franken linear, noted how it felt at the end, and then put the switches back together as they were originally. I immediately noticed that the top housing of one of the switches (that went on the bottom housing of the other), actually had a bit more play after being fit with the other switch’s parts.
So, it’s possible the fitment of even a similar type of switch be different for each switch. Thus is why we use films no? Some people actually only film the switches with a lot more play. Some people do them all. But those who film some always say that others didn’t need it. The reason probably is because the switch was a bit looser in its housing contacts… The plastic or whatever material prongs. So it’s possible a switch top housing is tighter and once it goes onto a looser switch’s bottom housing, it becomes too loose for its original switch…
I hope this makes sense. Just my own thoughts and theory using a bit of practical stuff to base it all upon. XD
I still mixed and matched before I had a switch opener. I took them all apart, bag lubed em and put em back together. I often am unable to finish a lube job in a single day. In fact, as we speak, I have an alps board with its guts laying all over my kitchen counter. Not saying you’re wrong, people are different so you could be right!
My suspicion is people who reassemble switches with all their original parts do so because they believe those parts have been broken in together over time and mixing up the parts would be like putting your foot in someone else slipper, even if it’s the right size, it wouldn’t be a perfect fit thus you would compromise your switch’s best potential for smoothness. That’s my theory anyway.
Yeah lately ive just been buying switches 200 at a time, take them all apart, and then when I’m ready to build a board just pull out piece for what I need and lube them and reassemble.
That’s actually pretty true as well.
Nice analogy @ddrfraser1
Damn… I would be forever afraid of damaging the parts @dwarflemur
Updated the guide with a new store SpecLub. Haven’t tried their product yet but I should have some coming in eventually. They have stock which is a rare find nowadays. I’ll try and report back once I’ve reviewed their “equivalent” 3203 and 3204.
I use one of these and put the different parts in each corner and the springs in the lub bag. That way I can just put it out of the way when not needed, and I can keep the lubes and paintbrushes and switch openers in the middle.
Your link doesn’t work for me but assuming it’s some kind of organizer case usually used for crafts/jewelry/beads etc. If so, I do the same thing and have never had a problem with that kind of storage.
weird, the link works for me. It’s not even that, it’s just a big tray. Maybe an organizer one would be better…
I use them to store my crayons
Might be a weird US/Canada redirect issue. Anyways, if this link works, this is what I use: Deep Utility Organizer by Simply Tidy™ | Michaels
Allows you to define your own bins to different sizes by adding and removing dividers.
bruh ngl I still got a bunch of crayons, sometimes you just gotta bust them out for a drawing. If someone asks for an explanation like they’re five of something you bet they’re getting a crayon drawing (no matter how complicated it actually is) lol
