On my desk but I moved it to get this shot.
Details: Moon TKL with lubed C3 Tangerine Milky Bottom Switches, r1 9009 PBT keycaps, Brass Plate, C3 LDN RGB 80% PCB, lubed GMK stabilizers.
Woke up this morning and decided that I should try to dome swap my 55g domes from my Realforce into my HHKB. I also took the extra spring from the space bar in my Realforce and used it for the HHKB space bar because I like that extra weight as I can be pretty heavy handed.
Bottom line. I like the HHKB significantly more than I did before with the heavier domes because I feel like I can actually rest my fingers on the keys now, but I think overall I like the feel of the Realforce with 55g domes best. Will I switch back? I don’t know it was a bit more annoying than I initially thought it’d be to dome swap. It was nice typing on an almost standard ANSI layout again for a bit. Think I may be getting tired of Topre though, so I may end up selling both of those boards to fund a build with a new hotswap board and Halo Trues.
So sexy!
Thanks!
Snappy, smooth, and joyfully loud
- switch: Halo stem, Bsun housing, 65g spring, lubed w/3204 lube
- plate: brass
- PCB: GH60
- case: Tofu
Keycult No.1 in military green with brass plate and weight, built with Gat Yellows and finished with Skidolcha. It is one heavy boy.
Leeku MX1800 PCB, Cherry MX silent black, Cherry 1800 case and OG Cherry caps combined with GMK caps.
Hawwww, a g80-1800
Get force curvy!
Damn I’d like to get my hands on that keyset!
