Tecware Phantom TKL brings back lots of memories - it was the first board I fixed out of necessity and served as the gateway
Do you have a picture of the PCB or the internals of your FL 980? I’m curious if the PCB is compatible with an aftermarket case (Heavy 9) designed for a Leopold FC980M/C
This is my first ergo keyboard (no split) and stack acryllic. I couldn’t be happier!
Keyboard: Av3 (B stock) and wrist rest by IV works
Layout: Arisu
Plate: POM
Switches: TTC blueish white
Keycaps: BoW MT3
Deskmat: Inukuma
Trying Topre for the first time with a FC660c 45g silent
Usually go for TKL or 1800, so form factor is an adjustment as well. It is different the MX for sure, trying to stick with it for a few days before cracking it open and start tuning it (have a Hasu controller and will lube it to start). Overall typing experience is nice, reminds me of Boba U4’s but less tactile. The windows key legend looks especially terrible. Red LED on caps lock looks ominous (which it should IMO). Don’t know about insert on the top right corner will probably change to F5
My desk is a bit cluttered right now trying adjust definately need to break out a numpad for work.
Edit: I made it a full 24 hours before breaking down and voiding my warranty installing the Hasu controller in my FC660c. Did I need to do this at 5:30 in the morning before work. Yes, yes I did, 15 minutes later all is better with the world.
There’s a nice review and disassembly of the FL980 which includes a side by side comparison against the Leopold FC980M
I love my 660C, and the Hasu controller was a game changer for sure. If you find that the spacebar feels too heavy or at least inconsistently weighted compared to the other keys (like I did), you can remove the outer spring under the key – this made me type faster and more comfortably.
I remember trying Tokyo Press for the first time. I was like, eh. Then I found myself coming back to it more and more. Then I sold it cause I hated the layout, but couldn’t stop thinking about it for like a year and a half. Then bought a 980C. I hope you like it.
TIL that Topre is short for Tokyo Press. Thanks! Some interesting history there too.
If you want more tactility try out some of the aftermarket domes as well.
I finished my MurphPad today, the P3D case is done in the Radiant acrylic. I had actually ordered a white one, but there was a mixup so I ended up with black. I may take it apart to spray the switch plate, but for now it’s good. Besides, in black you can’t really tell there’s a screen until it comes on.
Switches: U4T Black
Caps: MT3 Camillo
Knob: lovemyswitches.com
I love the “infinity mirror” effect of the stacked acrylic edges through the clear surface. What a cool pad.
I’ve also got some MT3 on my desk today; Susuwatri with monotone mods and red accents on *nixdork Boba U4Ts, in a KBD67 v3.
Edit: sounds in this thread
Hell Yeah !
Cool!
How do you like the Ploopy trackball? I want to get one, just haven’t pulled the trigger on it yet.
I got the ploopy mini and quite like it so far! I haven’t played around with QMK on it yet but initial thoughts:
Pros - 3D-printed shell is more comfortable than expected, trackball is accurate, clicks are nice
Cons - micro-usb
I had some trouble getting used to the ball not being on thumb position but adjusted pretty quick. Definitely won’t be my last ploopy product
Awesome, thanks for the feedback!
I’m still debating on whether I should get their mini or classic trackball, because I think I’d prefer those models over trackballs that you control with your thumb. Since I would like to use the trackball for everything, I feel like having the trackball on thumb position would make it harder to be precise when doing some casual gaming.
One of my four AEK-IIs
This one has white damped switches. Slightly different from damped cream but hard to figure out quite why.
I’ve been digging back into old stuff over the past week. When I get overwhelmed with all the new switches I tend to shut down and pull out old stuff. Ha.
Do you know of any vintage boards with AEK legends but with MX switches?
