What is on your desk today?
Today I am using the Freyr TKL on my desk! I really love that red plate and black case vibes. This board together with my HHKB Pro 2 are always on my rotation because they are so nice to type on.
Also, I just modded this board a little by removing the screws from the center mounting posts and loosening the 4 mounting screws (top and bottom) from left and right of the center posts.
The result - a very nice soft bottom out that is really fun to type on!
“Traditional” top mount boards can be a joy to type on with some modding, and it’s not always a firm or even “bad” typing experience as people made out to be. :smiley:
Buger TH01 with Bm60 PCB and G-MKY red samurai pbt keycaps and vintage mx blacks. no lube, no films, not really a fan of either of those 2 in most cases.
what a great set up! What keyboard is that? 65% right?
My desk at work.
I’m confused why that game pad is on the right side lol; do you actually use it with your right hand or do scoot over when you need to use it with your left?
Also, A+ choice on the trackball mouse!
I use my right because I turned the gamepad into a macro pad. Thank you.
Got my KBD67 Lite, so I did a quick build with:
  • U4s
  • Zeal stabs
  • MT3 Extended 2048
Unsurprisingly: feels good! Not a fan of the form factor, but it’s definitely a solid board.
How are the u4s cause my fingers are itching
We had a mini meetup today!
Nature is healing… :sob:
Finally decided to give one of my Hadflex60 PCBs a go & found out they are the ultimate 60% tray mount PCB! No joke,as long as your case only has the 4 side mounting points & you use a half plate it makes for an extremely bouncy typing experience that is consistent feeling across the board! Went with Pewters in this cause I had a batch ready from my hot swap setup & decided they’re good enough to be soldered in something.
Clutter
I just build that lite67 today and…
WOW
I am mind blown tbh. This board is like butter.
I added:
  • Durock V2 stabs modded with krytox 205
  • Zeal sakurios lubed with krytox 205, springs bag lubed with krytox 105 and filmed with deskkeys switchfilms
Soundtest: Stream kbdlite67 with sakurios lubed and filmed by ThicThock | Listen online for free on SoundCloud
I would love to get my hands on one (or two). I just missed out when they were in stock last. Do you happen to know if these will be restocked in the future?
Unfortunately I do not know when or if there will be restocks. I definitely want to grab some more also if they do run again. Here is the link to Hadi/Senseless Clay’s website which is currently locked, but where you’ll find them if they run again, https://senselessclay.com/password . Then here is the Geekhack IC post link, [IC] had60 - An accessible, minimal, and universal-ish 60% PCB. You could PM Hadi on there to see if might happen to have any extras laying around & if he plans on future runs of the hadflex60.
Testing out the new V3 KBD67 case, which fits the KBD67L internals. I opted for the painted brass weight, which it appears to share with the Bella.
I can tell you one thing - this keeb is no longer “lite” by any stretch of the imagination.
As one might expect, the sound is higher-pitched and not as resonant. The flex is reduced as well - though I’m not sure how much of this is that there’s a lot more weight on the bump-ons, and how much of it is the case itself.
I will say, the weight appears to be warped and only screws on at the edges, so it could be pushing up on the pcb and preventing it from flexing as it normally would - I’ll try it without the weight later and let you guys know in an upcoming piece I’m working on.
Initial impressions are mostly positive, but it is a tradeoff. The keeb now feels super-planted and solid, but it does give up the unique sound and feel of the 67L in the process. That said - the keys do enjoy a good level of consistency and the silicone still does its job of dampening sharp vibrations.
I’m assuming that this product is not only an upgrade for the 67L, but also represents the new iteration of the “regular” KBD67; with the sandwich-gasket mounting style as opposed to the top-mounting of the previous two versions. (I kind of thought they’d do this - makes perfect sense to me.) From what I can tell, this is a nice iteration in that line.
So - initial recommendations - if the sound and feel of the 67L are your favorite parts about it, this might not be an ideal upgrade - but if you know how heavy alu boards tend to sound with a little dampening and know you like it, this case offers a much more solid experience than the ABS version.
Edit: I’ll also add that this configuration is less forgiving of un-tuned or poorly-tuned components; it’s making the stock-ness of my KBD67L R1’s stabs a bit more obvious, for example - and it’s also bringing out a bit more spring chatter in the switches I’m using. I suppose that’s all well and good - higher-end materials might deserve a little more build attention, anyway - but it is something to be aware of.
I’m back in the office this week, no more working from home for me. But on the bright side, I get to have 2 keyboards in rotation again!
KBD67L R1 in V3 alu case
GMK Nines • Tecsee Diamonds • Brass Weight
I really like this. I haven’t decided which I prefer overall - this heavyweight metal case or the light plastic one - but each have their own benefits. I’m very happy with this keyboard - now I just need to re-tune the stabs…
I’m really surprised that the Dell laptop is able to run a triple monitor setup! Or is that a mini pc below the Dell?
HHKB Pro 2! I have modded this fella a few months back with 205g0 and deskeys silencing rings #5 to have it more silenced. Overall this is really a nice board to type on! It has this deep thocky “shork shork” typing sound, and I really like the tactile feel of it. I also like the simplicity, and low front height of this board, makes typing really fun!
This has been one of the top few boards that I use daily.
Changed the keycaps because I really can’t see with the original black keycaps :stuck_out_tongue:
Thinking of getting the 9009s keycaps from kbdfans to customize this again!
