Thanks for your write-up Nebulant, I’ll redirect to your post if anyone asks!
Here’s my addition. I’m not noticing the same alignment issues on my board but at the same time, I noticed you’re using the stock housings. I don’t seem to have a noticeable wobble or alignment issues when using the NIZ housing and stem combo. I stuck two pieces of electrical tape to both sides of the housings before mounting them to lock them in place, so now there’s no horizontal play at all.
Within the post I talk about using the niz housings and sliders as a pair with an updated picture of the number pad showing proper alignment. Together they work pretty well.
Ah yes sorry, I didn’t go through the full Imgur album before. Credit where credit is due, thank you for your research
For spacebar you can use 6u costar stabs. Works great, here were used 2 stabs to hold the wire better in position : https://imgur.com/a/jJKw1Qy
that is a pretty clever solution
My hhkb pro 2. Lubed with 204g0. Silenced with des #3 rings. Novatouched, including left shift, enter and spacebar. Sometimes I would try different keysets on it.
8 years passed by and it’s getting yellow a bit. Appreciated for its companionship so long.
So it sounds like these are a neat way to throw some MX caps on a topre board. Are there any mods needed other than the NIz product? You using the stock topre domes with them?
I’m not using the stock domes because I only had 45s and wanted something a bit heavier so I’m using BKE Heavies from Keyclack right now. But stock domes work just fine with the NIZ housing + Slider combo.
thanks! I want to try those BKE domes out as well. I have a variable weight 87U that I might try them out on.
ABKO K935P 45G - For $130 I was really surprised by this thing. I didn’t realize it came pre-silenced and now I want to add silencing rings to my FC980C and FC660C.
Realforce R2 TKL 55g silent, to enter my Norbaforce MKii VHS on arrival.
Imported from Japan to UK courtesy of the very proficient and highly recommended Zen Market [Http://www.zenmarket.jp] (no link to them, just saw their services recommended somewhere in this forum)
#thocklife
Thats a stunner
Hey guys, I have a HHKB Type S on the way to finnaly try one it’s the white version with printed keys.
Could you please tell me what mods do you recommend and what specific hhkb stuff is available ?
I novatouched a fc660c&980c , lubed them, added Hasu controllers etc.
Just want to know what specific things can be done to the HHKB and are available specific for it.
I’m also considering sticking to stock sliders but donno
There’s a HHKB Hasu, if you want one, but aside from artisans, that’s about it. You’ve already got the silencing down.
Very nice ! What sliders do you have inside ? How did you get a 6u SA Spacebar ?
