sucker for GMK though, sigh
Going to start trying to take more pictures now that I have a lot of space and better lighting. Here are some of the boards I have been using since I moved.
I like the ‘manofinterests’ E6 haha
Just finish the Brutal 60 build. KBD6X pcb, copper plate, Creamy T1 switches, and Brutal 60 case powder coated in soft satin white.
Blackplum 68% Keyboard.
Frosted Acrylic Sandwich Case, FR4 Plate, Gat Yellow Switch, Blackplum Hotswap PCB type-c
What spring weight did you use? Is the switch feel consistent across the board?
I ask because I tried to use 62g and half the sliders wouldn’t return so I had to bump up to 67 which was too heavy. Plus, the feel was inconsistent across the board.
How are you liking the build with a copper plate?
I absolutely love it! It looks the best and weighs a bit more than brass or steel plates. Its sound characteristic is quite similar to brass.
That’s very nice, man. Who did the case?
I make all the pcb, plate, and case, just inspired from qlavier’s sandwich case.
That COD67 with GMK Deep Space though
What kind of case is the last one? What is the material? (the keebs are glorious btw!)
The last one is a Nylon 3D printed prototype for a board I am working on as a one off. Built kind of like the Weaven, with interchangeable corner blocker sections.
Deep Space is such an underrated set
This is a really good idea.
