Okay, time to show the fullsize some love. MT3 WOB keys with Carbon SA extras on Gateron Milky yellows. The board is a Monsgeek M5 fully foamed with tape and force break mods.
Here is another board that was on my Bucket List. This one ticks ALL of the boxes for me, as I love red boards, 65% layouts, and simple, but beautiful designed weights.
While I’m not completely married to the keycaps for this board, they are a placeholder until a few more kits come in that I think may go better. WoB goes with everything, though, right?
Copper Slag Salvation
GMK Wasabi v2
Gateron Beers
Custom plate and PCB mill maxed with 7305s
I’m pretty happy with this build, especially now that I finally seem to have defeated the case ping. Put in 1/8 neoprene foam and orings under the pcb (like 1/2 a burger mount), and screws only tight enough to keep the pcb down. Hoping the ping is gone-gone.
Riiiiiiiiiiiiiiiiiight before I dropped it in the snow.
Swapped my 43Studios 4398 over to Oil Kings.
I had to swap the PCB since the first one had some issues. They ship with 120 little foam pads for the PCB, so I ordered a custom set of foam from Green Door Geeks. The plate in here is a custom POM plate also from GDG.
Just got my QK60 in cream and epbt origami matches almost perfectly. Got some stock U4Ts in there, probably have to lube them as they sound a bit scratchy and dry.
I also only noticed after I took the pictures that -/+ are flipped but super happy how milky this build looks.
