With the changes. The core should still be sufficient for the IC Kira keyboard and the Massdrop CTRL keyboard, correct?
Sorry if it appears as a double post, When I changed my username it says some posts might be broken so I deleted the initial reply, changed my username, then posted another reply.
Heya! Could you please remove this message please? we didn’t remove all the 1u ctrl, alt, fn keys, we just went from 2 to 1. And while it is true that we do not offer 1.5u Code keys in the core kit, we still have 1.5u alt and control keys so your message is a little misleading. We still cover the M60 layout just fine
Not to be a dick, because we are discussing the potential reintegration of those keys in the core kit, but it’s a render, and the fact that it displays those keys and they are not in the kit anymore doesn’t mean that the kit is not compatible with the board anymore. I mean, had the render pictured two ALT Keys, I am pretty sure we wouldn’t have that discussion right now.
